Originally posted by pappy:
Jack, welcome back...I've got a speedometer problem. It stopped working so I bought a new speedo cable and housing, still didn't work. Checked the angle drive on the ZF and the fork inside the drive had broken off. Replaced the drive and all seemed well for the first forty miles until the speedo head started bouncing and making a clicking noise. Can the cable itself stretch and start binding?...thanks
It may be possible that your speedometer small axle that is in your cable connection part isn't running smooth.
Please take out your speedometer and carefully put a little screwdriver in the hole where your inner speedometer cable comes in to.
Now turn the screwdriver, and it MUST run very smooth, if it doesent, it will destroy your cable and/or your speedometer driver.
You can put som wd40 between the rotating axle and the body to loosen any dryed out grease, and make it run smooth again.
