I looked through previous posts to identify my half shafts and still can't make up my mind what I have?
All the U-Joint caps are marked Spicer USA P1649, the Dia. is 32 mm and width of the U-joint 106.5 mm (Std dimensions?). There are no visible markings on the half shafts I can see and they would appear more like the std ones in Chuck Meltons photos (they have been turned with the smaller end inboard). Are there retrofit hybrids or OEM shafts with replacment spicer U-J's? I guess I may have to resort to the take it off and weigh it method!
Secondly, I was thinking about upgrading to the Spicer half shafts but assuming what I have is a 'hybrid' or 'retrofit' is there any real advantage?
Thanks,
