Coz, just go to your local Orchard Supply Hardware store, or other Store and pick up a 17MM 'L' Shaped Allen wrench! Thats what I did, there's little room for the side plug, but enough. The bottom is no problem. Trouble is it cost around $15. and the plug socket is at $12. But you still have to pay the shipping AND then wait!! Good-Luck!
From one of my previous posts:
I have found an alternative that works like a charm for under $10 and is as close as your nearest Home Depot!
In the plumbing section of Home Depot there is a tool made by Brass Craft (Model T143) that is called an "internal Pipe Wrench" for removing 1/2 inch pipe nipples. The main shaft of the tool fits perfectly in the ZF plug and can be used with a regular open-ended wrench, or cut off and used with a socket.
But keeping on-topic... aren't they supposed to leak? Smiler
They also sell the socket version at Checkers auto parts (but they always run out).
I have sold these on eBay for about two years. If you can't find them locally (Checkers, Kragen) on your own, I will sell and ship to you First Class for total cost of $10.
That is my fellow-PIBB-member good-guy price ;-)
(since I have no eBay or Paypal fees.)
And yea, I'm making a profit but gas is expensive :-)
