What is the stock spring rate for a '71 Pantera front and rear? What spring rate do you guys with aftermarket shocks and springs run? Would 400# front and 700#rear work ok on a street car? Thanks
quote:Originally posted by r mccall: What is the stock spring rate for a '71 Pantera front and rear? What spring rate do you guys with aftermarket shocks and springs run? Would 400# front and 700#rear work ok on a street car? Thanks
