I have developed a squeeky clutch pedal from under the dash. Each time the pedal is depressed - big squeek. Everything is working fine...just noisy. Car has been sitting for most of the winter(driven once a month). What is to be expected....broken return spring, master failure or just needs lubrication? Major road trip coming up. Thanks!
If you have a factory clutch master cylinder, it's probably the spring on the rod under the rubber boot.
I had the same problem and noticed it when I was reviewing some video footage I took from my camera I had mounted in the car. I found the spring was broken into three pieces.
Good luck... let us know what you actually find.
Blake, you didn't mention what year your Pantera is. Note that from mid-'72-up, there was an 'effort-reduction' kit installed in the clutch pedal linkage under the dash. This adds several links and pivot pins that run steel-to-steel, none of which have ever been greased since the car left Modena (and maybe not even then). This is, as you say- likely not a quicky spray-it-and-forget-it thing....
Note also that the mousetrap-spring on the clutch shaft regularly breaks and is not worth replacing; a new one will only break soon after you fix it, and it requires dashboard removal to R & R it.
I have a buddy here in Phoenix that has on several occasions replaced the clutch and brake pedal return springs under the dash. Without tools, laying on his back, by carefully winding them on. Mines been working fine for 5 years since he replaced them. Would you believe he did it in just a couple of minutes too!
Jack speaks the truth! If you have the effort reduction kit (standard issue starting in late 1972), it's quite possible the sound you are hearing is the assembly eating itself.
There will be a tech article in next month's PCNC newsletter showing what can happen if you let things go too far for too long. A poor fellow in San Diego really destroyed his linkage, and the clutch stopped working completely. It's easy to fix (by replacing the worn-out parts) but the real solution is to lubricate everything thoroughly.
Here is what the system looks like. This is with the whole pedal box out of the car; the view is from the center of the car, looking to the side. Get in there and lube everything and hope for the best!
  • ClutchLinkage
