Hi,
I am in the process of 'freshening up' my '74L with 15k miles, and I have a few questions.
I've noticed the rear Telecar coilovers are still blue but the front are black. I can't find any blue paint underneath, should they be blue or black on the front? It looks as though someone has 'had a go' at the front suspension as it has been fitted with 'modified and ill fitting' neoprene bushes in the front suspension arm pivots.
I've read that there is a modification to increase the caster that involves cutting and welding the upper arm ...... but I've also read that machining the upper ball joint the same amount as the thickest shim will increase caster. Will this be noticeable? The car is to be driven 'spiritedly'!
7259 is in pretty good condition, not too many parts are worn out, it feels as though it just needs pulling apart, and re-lubing (except for the prior 'work' on the front suspension)
Any information you can assist me with will be much appreciated.
Thank you,
Matt
