Hi
i finally got my pantera.
it has an issue with the steering, the steering id real notchy, and the colum slides in and out !
I have noticed the colum bushes have fallen out of the lower of the column, i can pull that and fix it, the knuckles all seem tight, but the slip joint just before it goes through the firewall is where it slides in and out.
it also seems the shaft that goes through the firewall possibly into the rack has slop in it ??
any help will be greatly appreciated.
