They sometimes seize up from age and complete lack of lube as the tiny bearings are unsealed. I once tried rebuilding those cheap little u-joints (same as those in the shifter shaft) using new needle bearings and adding o-ring seals. In the end, the time spent simply wasn't worth the trouble. Use new ones especially in the steering to be safe.
