quote:Originally posted by Rob Borruso:
Very cool Mr. McCall.... I likey...![]()
quote:Originally posted by pantera chris:
new Momo
http://pantera.infopop.cc/eve/...191000166#7191000166
I'm surprised that Chris is the only one so far to show a D shaped steering wheel. I've had mine since 2001 and think it's the only way to go, and I'm only 5' 10" tall with normal length legs! I also like the contoured grip areas which make it very comfortable.
I got the hub and removable adapter from Panteras by Wilkinson. Not only is it a good theft deterrent but it also makes it really easy to work under the dash in the footwell area! I believe mine is 340 mm (about 13") but others may be available. My particular model is out of production but can be found on eBay. Chris' is in production. His is the Trek model, but others are available. Just google Momo D shaped steering wheel or flat bottomed in place of D. To restrict to what may be available now, click on tools and "Past year" or what ever. Try clicking on images too.
I don't know what hub Chris used, but the Trek wheel doesn't look like it would work with Wilkinson's removable adapter. You need one with a hole in the center and clear access to the standard mounting holes.
quote:Does anyone know the proper spline count and diameter?
quote:Originally posted by over50:
My car came with a LeCarra steering wheel. It is 13 1/2" OD and has a 1 1/2" deep dish. It also has a bow away from the dash at the top. I don't have any leg clearance problems. It is very comfortable to drive with the top bow.
It is hard to get a picture that shows. I looked at the LeCarra website but it isn't very good about details of the wheels they sell. This might be what they call a Mark 4 but I'm not sure. You will have to call LeCarra to find out what I actually have. The top of the wheel bows toward the driver about an inch.
I'll try to get more pictures or measurements if you want.
Norm
FWIW, MOMO Prototipo's are made of a non-weldable aluminum alloy. I TIG'ed one back together for a friend and it lasted a month before cracking next to the weld.
WOW, there is a lot of Ugly steering wheels being fitted sorry to say, i think the Steering wheel design is crucial to the overall look of the interior. I just use the Stock wheel
