Most air cleaners are very similar. There are probably 5 or 6 sizes (from 16.79in to 18in) and a couple different covers. The variations are in the snorkle designs/with or without vacuum valves and locations or holes for hoses. The one on eBay will go for big bucks because of the rear air valve. Now the Pantera air cleaner has some specifics you can keep watching some come-up every once in a while. But if you are good with a MIG welder you can easily clone the original one: the part number is different for '71, '72, '73. Just identify the correct size of the bowl's outside diameter to ID and get welding. The snorkle is the same as a 71 351/400.
