Thanks I think the measurements are 10 length, 7" wide and 8" height around there somewhat. why does everything have to be so difficult.
Least right now from the little I have done she starts right up and idles great.  Long tank is not leaking as of now since I took it out banged all the rust out of it that I could and then sprayed it with FlexSeal.  Temporary fix. I fixed the drain plug leak which was making me lose sleep.  It was already single over I saw 1/2 on the plug. I ran another plug in the and fixed the threads pretty much so that the plug went all the way in and got it tight with a new crush washer. No other junk sealant or anything. Not a drop. Still need to replace harmonic balancer and the seal behind it. Weird seeing the car out in the driveway after so long.
Thanks for all the battery info.
