I replaced my stockers with a replacement set from Hall that changes things slightly. The retractor fits without modification into the cutout on the inner rocker panel right by your hip. The top bolt over your shoulder is the second anchor point. There is nothing on the bottom of the firewall anymore so when I had my interior done I had that area covered over.
Works pretty well, except the retractor hangs up sometimes until you get used to pulling it out in a continuous motion.
Gary #06984
Nils. I just added a "swap out" drivers seat using a Corbeau Forza (in yellow of course), with their 4pt snap-in set. Very comfortable with the thinner 2" straps and holds you right in there.........now........ they also offer (if you dont wanna swap belts, but when i pull the forza i snap-out the 4pt also) a retractable 3pt you can adjust. Loose for daily driving and locked for auto events.
Bob
