George, in a previous thread you mentioned something to the effect that a Cleveland block stroker needs to be limited to a certain stroke.
Did you say 3.85"? Where does that number come from?
I have seen sonic testing on a D2AE-CA block and an XE block. The walls on the D2 are as thick as the XE.
If the D2 fails on a 4.0 stroke then the XE is likely to also.
Can you show me where that data derives from, please? Thanks.
Hi Doug,
My thoughts on the stroker kits are not influenced by the Cleveland’s thin cylinder walls, but rather by the wrist pin location on the piston and the rod to stroke ratio. The cylinder wall issue is indeed a consideration, but that is the case even with an oem stroke motor. Another consideration with stroker crankshafts is the width of the block and the height of the camshaft. In the case of the 351C and the 351W, there is plenty of clearance for the longer stroke crankshafts. The final consideration is how far out of the bore the piston is yanked at BDC. With the longer stroke crankshafts, the answer is pretty far, but livable.
You're an old Cleveland guy, so I don't need to explain in depth that our beloved Cleveland motor has a big ol' notch in the piston dome for intake valve clearance. That notch limits how high the ring package can be located on the piston. This in turn limits how high the wrist pin hole can be located before it intersects the oil ring groove. Some owners/builders have no problem with the wrist pin intersecting the oil ring groove. Personally, I do. It results in excessive oil consumption. For a strictly track motor, or a show car, that's OK I guess, but for a street motor, I disagree. A fellow should be able to go on a trip in his car without having to carry 3 quarts of oil in the trunk.
So, if the criterion is keeping the wrist pin below the oil ring groove, we have to consider crank stroke, connecting rod length, deck height, compression height (wrist pin center to piston dome), rod length to stroke ratio, availability and cost of parts verses custom ordered parts, etc.
I come from the prehistoric era, when running a solid lifter cam in a 3.5" stroke motor was normally accompanied with a 6.0" long connecting rod, for a connecting rod to stroke ratio of 1.7:1. A minimum ratio for a performance motor was considered 1.55:1. However, with the advent of inexpensive stroker cranks, that whole issue has been blown wide open. Some well known engine builders still prefer a longer rod to stroke ratio, but others, some very big names, say it isn't that important. Scat has the best reputation among the inexpensive stroker crankshaft providers. Below is a list of their popular kits & the various dimensions.
stroke.... rod length.... pin height.... r/s ratio
3.75……....…6.00…........….1.325…........…1.6:1
3.85…....……6.00…....…......1.275….........1.55:1
4.00…....……6.00……..........1.200….........1.5:1
The wrist pin of the 4.0” stroke kit intersects the oil ring groove, that kit also has a connecting rod length to stroke ratio that is less than what some builders consider minimal. Bob at Scat cranks has told me he feels the rod to stroke ratio of his 4.00” kit changes the high rpm characteristics of the motor. I would also say that 4.00” is a prudent limit when it is considered how far the piston is pulled out of the bore at BDC.
So the 3.85 kit is the longest stroke kit you can purchase “off the shelf” that avoids the issues of wrist pin location and rod length to stroke ratio. It is a reasonable kit, not quite as radical as the 4.00” stroke crankshaft. That is why you have read me recommend it a few times. I don’t have a problem with the longer 4.00” stroke crankshaft, as long as it is given the budget it deserves to do it right.
Where money is not the issue, there are things that can be done to get around the wrist pin location problem while using the 4.00” stroke crankshaft. For instance, building a motor with Yates heads will do away with the need for the big notch in the piston; you can shove the ring package higher, and keep the wrist pin out of the oil ring groove. A custom set of 5.925” long connecting rods will allow the use of the pistons from the 3.85” kit, with the 4.00” stroke crankshaft. While this keeps the wrist pin out of the oil ring groove, the resulting rod to stroke ratio is 1.48:1. Although some engine builders would shake their heads at this ratio, others would not. It is the same ratio as the oem 400 cubic inch small block Chevy. A third solution is to carefully map valve to piston clearance near TDC, and choose camshaft lobe profiles that will prevent valve to piston contact with little or no notch in the piston dome. This would allow the location of the rings to sit higher on the piston, keeping the wrist pin out of the oil ring groove.
In considering the thin cylinder walls, the “failure factor” all boils down to how the motor will be used, the red line of the motor, how much power the motor shall make, how well the motor is tuned, etc, etc….These days, most guys fill the block with grout to the bottom of the water pump passages which is roughly 2 ¾” below the deck. My advice would be to fill no higher than the piston dome at BDC. The grout strengthens the cylinder walls, prevents them from flexing as much, improves ring seal (from less wall flexing) and makes more power as well as improving the blocks durability. Cylinder wall failure has led some engine builders to take the position that 3.75” or 3.85” stroke kits are a prudent limit.
Other things that can be done to reduce stresses on the block, are to employ a lightened crankshaft, lightened connecting rods (I beams not H beams) and lightened pistons; and then have the reciprocating assembly dynamically balanced. I recommend taking these steps with all stroker crankshaft installations, and even more so with that longer 4.00” stroke crankshaft.
Strokin’ it with my buddies on the DTBB
  • 4_cycle_engine_large
So if I use a meat thermometer and fill the block with grout, the steak will be medium rare if I use a 3.85" stroke and a forged crank? Smiler
What high rpm characteristicsdid "Bob" say were changed with the 4"?
I'm not convinced the 3.85" is even too safe with what the blocks showed on the thrust surfaces. A 383/3.75 might be the max.
I don't want to get embarassed blowing up the engine when I'm backing it out of the garage at 10K.
The XE block is no stronger then the D2 in that (thickness) respect. It simply will fatigue less because of the greater thickness in the oil passage area and in effect has a cast in girdle.
With a girdle on the D2, I don't see any advantage. They are both high nickle blocks.
Thanks for sharing your information, the meat themometer says the grout is dry so I need to flip the steaks and shift into 5th. ciao.
Doug,
The XE block is thicker in the pan rail, the bulk heads up to the cam in all 5 areas, the 4 bolt main caps, and the Cylinders. I have both engines side by side and the XE weighs exactly 28 lbs more. Now I cant speak for all of the Xe blocks I can only speak for my two. The other is a D2AE. Also mine is a true NASCAR block as it shows signs of 1/2 IPS holes where it was used as a dry sump block. The block is out getting sonic tested as we speak. Exact specs will have to wait unitl they come back.
I do agree with George and you as we also feel the 383 SCAT cominbination is the best for our applications. Not that others dont work. But keeping in mind the piston clearnace at the bottom of the stroke and with out intruding the pin into the oil ring and keeping the valve notch also some distance from the oil ring. For us that application is best. Also considering we are running a little higher compression the larger cubic inch is not necessary.
Ron
Only the hardness test could say scientifically. Hopefully Dan can get a Brille test done eventually on them all.
The D2 blocks do seem to be harder then the other C blocks. Are they as hard as the XE? It's controversial to say the least.
On my first D2, the shop really got mad at me. He seriously thought I was lying to him about not having a "special" block just to cheat him on time and therefore his bill. At that time I honestly didn't know what he was talking about. I thought a block was a block.
It isn't that there is argument over them. They are what they are.
Some guys can break anything and some don't ever seem to break. Maybe it's due to carefulness maybe just good or bad luck. Maybe Voodoo? Unobtainium maybe?
The nature of racing itself just always pushes parts past the limits.
I remember when Grumpy Jenkins would be in the pits. He'd pull out his dip stick and start looking at it under different light angles and then with a magnifying glass. In no time so would everyone else. They wanted to find the secret to the Holy Grail too.
I'm sure for pure racing the XE is best. It's at the very top for the era.
The cracking through the web and into the bore would suggest block flexing. Extreme rpm may be the culprit.
I know the block can be stiffened 10% with screw in freeze plugs.
I know that the block can be stiffened with a girdle. I don't know how much.
The difference in strength between cast steel and forged steel is less the 10%. (100,000psi vs 95,000psi tensile) Of course if the forged steel is already over the limit then the cast steel is already broken? Is cast iron steel, not at all. Is high nickle cast iron (whatever that is) 10% stronger then regular iron (whatever that is)?
If you can stiffen the block it will reduce the flexing and the fatigue through critical areas.
Look at the bracing in the iron Genisis iron FE blocks.
Is it enough? who knows for sure?
I only asked about the stoke because I was thinking of build a stroker. The XE is heaftier yes but the sonic testing showed it the same as the D2 in the thrust areas. So that brought up the question of how much stroke, how much hp, etc, etc.
I remember being told how the development of steel was such a revalation for structures.
Before it there was just cast iron which is not good. Here we are working with cast iron still.
Doug, just a thought about your tougher than normal D2AE-CA block. It seems there is evidence that the blocks cast in the land of OZ were cast of a tougher grade of iron, compared to their US cousins. The casting number for the standard production Aussie blocks is the same D2AE-CA as the '72 - '74 US blocks. Is it possible your D2AE-CA block is an Australian version? Is there a CF or a GF in the rear, near the oil sender passage?
Regarding the cylinder wall thickness of the NASCAR block, the consensus is that the walls were perhaps just a small amount thicker than a US production block, BUT they were tested for core shift prior to shipment to the US, and only those with the most uniform cylinder walls were shipped for racing use, the remainder were installed in production autos in Australia. So the blocks employed in Ford's US racing program are not plagued by the random thin spots here or there that are found with the producton blocks. Since the late '80s some the "rejected" NASCAR blocks have been pulled from Australian wrecking yards and sold to Cleveland enthusiasts both in Australia and the US as the real deal NASCAR blocks. Well, technically they are, but they have greater core shift than those used in Ford's racing program.
your friend on the DTBB
It was out of a European Pantera, circa 75. The foundry mark is not readable. The Ford logo isn't readable.
There is a number stamped into the front of the block where the timing chain cover bolts up.
That is where the Australian blocks have a serial number, chassis number stamped in.
Mine wasn't a chassis number. 17G9. The 7 actually looks like a combination of a J and a 7.
The sonic test was .180" on the bore walls.
So long as the thrust walls are no less than 0.125" and the "side walls" no less than 0.080", maybe even 0.075" in a spot or two, the block is good to run.
I heard people refer to thin wall blocks as paper lanterns, I always get a chuckle when dealing with this subject. They're pretty thin aren't they?
If you have apprehension about a block being capable of sustaining the abuse you're going to subject it to, I'll share with you Cleveland Old Timer secret number 17. The solution is to bore all 8 barrels & install 8 "dry" liners. The liners are much stouter than the cylinder walls in the block casting. So even though they're thinner, the liners will make your cylinder walls indestructible; like a Timex watch or Samsonite luggage.
I still have a couple of other little tricks up my sleeve, for another time.
Until somebody makes an aftermarket Clevlenad block, I think the best solution is a Dart Sportsman block. They are $1900.00 from ADPerformance and can be bored and stroked out to around 440 inches total.
A 427 with a 4.00 stroker crank and 4.125 bore is no problem for this block. The quality is high, you don't have to run around trying to find a "good" block.
Yes it is a Clevor, but what is wrong with that? It was good enough for the Boss 302's, why not a Boss 427?
Doug,
The dry liners will fix your 0.100" cylinder walls, and the resulting cylinder wall will be tough as nails. Dry liners are far more reliable than wet liners, which have to be furnace brazed in place. Folks often have problems with wet liners.
DeTom, I hope that answers your question as well.
Chris, Doug & All,
a SERIOUS player has begun design of a HD Cleveland block. This fellow has already marketed a block for the 427 FE. He says he only needs 300 orders at $2000 each to make this project viable for him. That's a breeze. A new Cleveland block is closer than you may think.
your very excited friend on the DTBB
Originally posted by DeTom:
But Doug, I thought Genisis blocks run about 5K?? If I remember right complete engines were about 15K. Which is a lot better than the shelby alloy 427FE which ran about 40K or so.
The block is about $3200. You can just about use any FE heads that you can find. You can get a 428 crank for about $500 and 428 rods for about $150.
The block is the expensive part. You can use Edelbrock aluminum heads too.
You can build one for about the cost of a real HP C.
Originally posted by DJEZC:
...Until somebody makes an aftermarket Clevlenad block, I think the best solution is a Dart Sportsman block. They are $1900.00 from ADPerformance and can be bored and stroked out to around 440 inches total.... The quality is high, you don't have to run around trying to find a "good" block....
...That is very good advice...
Originally posted by george pence:
...a SERIOUS player has begun design of a HD Cleveland block. ...He says he only needs 300 orders at $2000 each to make this project viable for him...A new Cleveland block is closer than you may think...
...for that kind of money I'd go a little more for a 427 with a genisis block...
A $1900 Dart block is good advice, but a $2000 HEAVY DUTY Cleveland block, the block every Cleveland enthusiast has dreamt about for 30 years, is out of the question? No parts are interchangable between the Windsor & Cleveland, so by the time you purchase all the other hard parts you need to build a Windsor or Clevor, the price tag will easily be another $1000 in parts that you would not have needed if you had kept the Cleveland.
Doug, I only offer the information to inform all on the bulletin board. I did not write you should sell your XE block & purchase the forthcoming block. If that's what I had meant, I would have written so. No beating around the bush where I am concerned.
Sorry, I'm flustered by the Quella 427TP car.
Remember how Richard Dryfus reacted when he saw Susan Summers driving the T-bird in "American Gaffitti"?
I'm like that. Saying things I don't mean and wonderin' around looking in closets and shoe boxes and under furnature.
It must be cubic inches I'm looking for. What else can it be?
I'm very vulnerable now. Be gentle with me.
Heavy duty Cleveland block possibilities:
4.125" bore x 4.00" stroke = 427 cubic inches
4.185" bore x 3.85" stroke = 423 cubic inches
4.185" bore x 4.00" stroke = 440 cubic inches
Imagine 427 cubes being fed by your A3 heads! Dude, that would make you forget about that FE motor, wouldn't it?
But George if you really, really want a 4.25" bore with a 3.50" stroke, it only leaves you one alternative.
