I removed the tail light housing and and when I reinstalled it, the passenger side tail light stopped working. I removed the plastic housing, made sure the wires were attached to the ground but it still doesn't work. The wiring diagram shows a ground to the a/c condenser which looks OK. Is there anything I should know about the tail light housing that could be causing this?
