I bought a (rebuilt) motor at a swapmeet so I could drive the P car while I rebuilt my original motor. I pulled the pan--4 bolt mains, I pulled one head--screw in studs--adjustable crane rockers--closed 4v heads--everything looks good as in (rebuilt)--and the price is right. The only paperwork I got on the rebuilt motor was the cam card--Hydraulic Lunatti Monarch cam. Nothing but assembly lube in this motor. Just bolted it in and drove it about 500 miles and motor is strong. Then motor started a valvetrain ratteling sound at 2400 RPM only--like a couple of loose rockers. I pulled the covers and readjusted the valves one turn down from 0 lash. I take off for a drive to work and the motor is now making more noise and has a little miss. I take off the valve covers again and notice one lifter not supplying oil to the rocker? I take out the bad lifter and it looks like maybe it's not a 500 mile lifter--shows wear on the body--but the bottom looks fine. Another lifter looks the same--some wear marks on the body but the cam side looks new.So I order a set of new hydraulic lifters.
Replacing the lifters I notice 4 bent pushrods? Not visually bent unless you roll them on a piece of glass. I have a set of pushrods from my old motor but I start to think? I took apart a lifter and it's a solid lifter--anyone run a hydraulic lifter with a solid cam-or vice-versa? I have a boroscope and the pistons look like no valves have ever touched them. I am running a steel gear on the distributer and see no wear signs there. I now don't know what camshaft is in this engine and wonder what harm I might do running hydraulic lifters? I would like to use this motor for another couple of months--George?
