There are only a few things that can contribute to non-working rear calipers: first, the steel- cable-with-steel-jacket often gets rust or corrosion inside. Disconnecting the cable, moving one end of a jacket to a high spot & taping a paper funnel around it will allow you to run oil into the assembly & possibly free it up. Second, if one of the rear calipers has a stuck piston from build-up of varnish, you can disassemble the offending one, polish the piston with scotchbrite and reasemble-no parts normally needed. Finally, those calipers are designed to slide back & forth in operation so a dab of axle grease in the sliding channels once a decade is a good idea. Removing the brake pad exposes a setscrew that sets the sliding clearance and this also might need adjustment
Jack, I replaced the cable and that did the trick!! You're amazing. Thank you...again.
