I about to replace the rear axle bearing and I was wondering if anyone had the Timken inner and outer bearings and seals part numbers.
I saw there was an article regarding installing oversized double diameter inner bearing and machining the axle spacer down. Does anyone have a Timken part number for the oversized inner bearing?
Thanks
