Hello guys,
I need some advice regarding wheels and tires for my Pantera. Currently I am running 15 inch wheels with 345/35 15 and 225/50 15s tires. The car has very good acceleration and handles and brakes very well with a modified braking system. I know the speedometer is off because of smaller diameter tires and it also has a red line limited top end. Since I plan on checking my speed with GPS, it is not a concern for me and I don’t care much for the top speed. My priority is good 0-60 acceleration and good braking. I also have a spare set of 17 inch wheels with 335/35 and 245/40 17 tires that I purchased for future use because of non availability of 15 inch tires. The 15 inch 345/35 rear tires on the car are 24.8 inch in diameter and 17 inch 335/35 rear tires are 26.2 inch in diameter. If larger diameter tires are installed then is that going to hurt acceleration and braking ? Is there going to be a noticeable difference? Both 15 and 17 inch wheel combinations weigh about the same. Any advice is highly appreciated.
Thanks
Shah
