I am in the process of installing my front lower a-arms with polyurethane bushings and was wondering what kind of torque values do you use with these type bushings. I have read where a torque value of 58 ft. lbs is used for the control arms with OEM type rubber bushings, but that seems like an awful lot for the poly bushings.  Can anyone tell me how tight these bolts should be?
Thanks!
Yes, the bolt has a sleeve around the bolt. The sleeve seems to be approximately the same length as the total length thru the bushings. I was concerned about getting the torque too tight and wind up compressing the bushings and putting them in a bind, particularly when the mounting tabs seem to be right up against the bushing and the sleeve.
