Can anybody tell me what the torque spec is for the Stub axel is
quote:Originally posted by Bosswrench:
...Do not worry about stripping the threads- that size nut strips in mild steel at around 1200 ft-lbs.
...the internal spacer between the bearings is also mild steel and if slight wobbling occurs, the spacer will be indented on its ends, which shortens it.
...distort the thin steel outer bearing retainer ...
