Wheel ramps for the tow vehicle.
Mine aren't here or I would measure them but I believe they are 14" high.
Hook up the trailer. Put the ramps behind the back tires of the truck. Back up onto the ramps.
This obviously lifts the back of the truck but also drops the back of the trailer significantly. Takes the steep pitch out of the ramps perfectly.
I can drive straight up with the kids toyota mr2 and his air dam is 1 3/4" off the ground.
I bought mine but with your fab skills you could put a set together in about 5 minutes Wink
Doug M
If you are not trailering far you might want to consider a "Tow Dolly".
I use them quite frequently with great success & ease of operation.
To achieve the least ramp angle, just use a couple of 2"x12"x6' in addition to the car dolly's ramps.
A couple of heavy gauge screws screwed to the underside of each plank with a 2" of screw shank exposed will fit/drop into the open webbing of the metal ramps to ensure your planks don't slip when driving/winching your Pantera onto the car dolly.
I rent from Uhaul for about $44.00 for a 24 hour rental period...Mark
http://www.uhaul.com/Trailers/Tow-Dolly-Rental/TD/
Trailering a lowered vehicle or with a low air dam require ramps with a very gradual angle which mean the are also going to be longer than a standard car ramp. Use 2x4 posts as pre-ramps to the front tires to raise the front end enough to clear the ramps so you can drive the car onto the trailer. Just go slow and have a second person spot for you if possible.
I made some step up ramps. I actually had to put the front on ramps before I could jack the rear of the car. I was figuring on building some longer ones for the trailer.
I was not sure how much air I could put in the air bags. I initially stopped at 100lbs. After researching the bags it seems 150 is acceptable. At 110lbs the front really came up so I am not as concerned about it as I was.
Your air bags will handle 150 psi.I have the Ridetech, we run that pressure.
Thanks, mine are too. I just had not looked into it. I was being cautious with them till I knew.
The other thing is since it is parked in the garage, running the pressure up required the wheels to scoot a little. If I was driving it I think it would pop up sooner.
I have an on board tank. I don't like running the on board compressor long it if the engine is not running so no to run the battery down. I added a fill point right behind the driver seat so I can fill it up with the air compressor.
