I'm getting my car ready to pull the transaxle to replace the clutch, and related parts, so I'm loosening all the bolts in preparation of the actual pull.
However, I understand that you must tilt the back of the transaxle up to clear the tabs on the rear transaxle mounts. I read that the motor mounts must be "loosened" in order to tilt the engine and transaxle assembly to get the transaxle out. Can I do this by loosening the three large bolts on the bottom of the frame that hold the motor mounts to the frame? How loose do they need to be? Should I loosen them only to the point the nuts are still on the bolts?
Any advice is appreciated.
Thanks.
