anyone have a good source?
quote:$8 or $85 for a pilot bushing depending on your level of risk management.
quote:Of coarse if you do not understand clearances and tolerances and it happens to fit loose and it works,
well I guess you have luck on your side.
quote:Whelp, I guess I hit a nerve. If you need help with your Pantera their is a quality shop 15 min down the road in Lake Elsinore; Full Throttle Pantera,s run by Don Bryar's. he may be able to help you on such matters. He has some very nice and over the top Pantera's in his shop worth the trip.
Mark
I think Mark sums it up pretty good...
I appreciate the vendors making parts for us, but I feel this thread (heated exchanges notwithstanding) provided a lot of value in discussing alternatives.
I used a Timken Needle Bearing - based on expert advice and the fact that these bearings have run in millions of cars for many years.
Here's a list of what I think works (YMMV) - I got one of these...
Pilot Bearing:
Summit: Ford D8TZ-7600-A
NAPA: FC-65662
Pilot Bushing:
RAM BU50J - Bronze, Non-Magnetic
McLeod PN 8-1380-2
Pioneer PB-50J
Dorman 14656
Kevlar Pilot Bushing:
Southbend Clutch 50MHDK
quote:Isn't this thread also a little bit about supporting and promoting those here who have gone out of their way to source, engineer, create and supply the best they can for the hobby? Like Marlin and Scott?
I wonder what Dorman would charge to tool up and supply the real bronze SAE oilite machined pilot bushing in the quantities we consume?
Hello Scott; I agree Wholeheartedly in regards to supporting those that use their collective skills & knowledge to machine/manufacturer/produce well designed parts & upgrades for our cars.quote:Originally posted by ZR1 Pantera:quote:Isn't this thread also a little bit about supporting and promoting those here who have gone out of their way to source, engineer, create and supply the best they can for the hobby? Like Marlin and Scott?
I couldn't agree more Larry. I think getting the part from Marlin is a great idea because he supports the hobby and does GREAT work.
My only issue is the scare tactic that some people use. Some folks are always doom and gloom on some subjects without any backup of what they claim to be a huge issue.
I say buy from Marlin because he supports us and make a great product, not because the less expensive parts are going to cause thousands of dollars of damage to our input shafts because that, in my opinion, is hogwash. Now this is the point where someone is going to say they saw it way back when... I get it, maybe someone experienced some issue with a non pure bearing but I still don't think there is much risk. Just my opinion...
But again, buy it from Marlin because he is a great guy supplying great parts. That alone is worth the extra money his part may cost.
Scott
This is Excellent advice/recommendation!...Thanks, Marlin Jack!quote:Originally posted by Marlin Jack:
...Hardened ZF Input Shafts ARE Absolutely Repairable!!! You First have them 'Hard Chrome' (Plated) and then they are Ground to size, between centers on a Cylindrical Grinder! Concentricity Accurate to 'Zero Error'. We do 'It' all the time at the LFW Shop. When ever a Shaft might be cut .001"-.003", or More, Undersize, in error. Chroming Saves an Expensive piece of Steel, with MANY man/hours of Machining on it, from being Scrapped. There is NO reason why a Shaft that might be 'All Galled-Up' could Not Have the Snout completely Chromed and Ground, the Very Best way to do it. Brazing and Welding is a Complete NO-NO!! Because it changes the Metallurgy of the Steel and Weakens it, at the very least!
Think of all the Worn-Out ZF shafts that CAN be Rejuvenated! YES! And the Surface in Hard Chrome would be BETTER than NEW!! Save a LOT of Money!
Call LFW Machine in Stockton, California for a Quote. Leo is a Master Machinist! No one is More Experienced on the Cyl. Grinder.
They Chrome Crankshafts! They also weld on Crankshafts. I Recommend Chroming.
I am Now retired and No longer work there.
Good-Luck
What is the thickness of the oilite crank bearing/bushing? I know the od and id, but not the thickness.
