The local auto parts stores have no cross references for Pantera trunk lid lifts (gas struts). I need ones for the stock lid, without a rear fin. Does anyone know of a substitute part that will work? Thanks Ray Cooper
[QUOTE]Originally posted by Ray C: [B]The local auto parts stores have no cross references for Pantera trunk lid lifts (gas struts). I need ones for the stock lid, without a rear fin. Does anyone know of a substitute part that will work? Thanks Ray Cooper
Ray: I bought mine from Wilkinson (www.panterasbywilkinson.com). Paid $85 for the pair. They fit perfectly, work fine and take about 15 minutes to install. Other vendors have them as well (www.panteraeast.com).
I bought mine from a Pantera vendor as well. If you are going to try to find a generic replacement, be aware that if you get it wrong you can bend your rear decklid (which is why I bought from a vendor). There are stories about people putting on a too-strong set of shocks which continually applied pressure to the decklid and eventually bent it. Food for thought.
------------------ Charlie McCall 1985 DeTomaso Pantera GT5-S #9375 "Raising Pantera Awareness across Europe" http://briefcase.yahoo.com/gt5s_1985
