1. Remove the 4 bolts that hold the steering column to it's mount. Lower steering column down and let it hang CAREFULLY. 2. remove the two plastic housing halves on either side. 3. (guessing now) Remove the signal switch mounting bolts. 4. Remove one wire at a time, and transfer it to the "new" switch. Or all wires come off in a plug. 5. Installation is the reversal of the preceding. Marlin.
