Rear Crossmember (with snapped swaybar stud):
Any thoughts and ideas would be most apprieciative.
Thanks,
Angelo
quote:The heavy stuff in the engine compartment took only a day to remove, the scrubbing is taking all of the time, but that is because I have a bit of O.C.D. when it comes to doing things throughly.
quote:Originally posted by ehpantera:
Don't plan on Daytona this year as they are repaving it right now. The event was canceled some time ago.
quote:Originally posted by ANGELO B:
..... but was wondering about the larger one above it. Is there any reason for it to even be there? Has anyone filled theirs and have a pic of it? Now would be the time for me to do this.
Thanks,
Angelo
quote:Angelo, great job on the sheet metal. Not sure I would close off those holes. I would consider the ventilation that it provides to let air in for drying in case water somehow seeps into the area. Also it gives you an opening to spray rust converting chemicals into the area every few years if necessary. Although the hole also provides a nice place for water to enter.
