Under that beautiful red bodywork is where most of the updating has been accomplished, including a complete Willwood vented rotors braking system, aluminum front hubs, adjustable coil over shocks and complete new sway bars/mounts.
A steering rebuild/re-bush and bump steer spacer installation (thanks Mike Drew) means that soon after this successful test drive return, it will be on it's way to Sonoma Raceway for a complete alignment and corner balancing.
