Beginning a bare metal restoration on my Manguta, and would like to know what upgrades, modifications, and alterations could, or should, be implemented while the car is in this raw state.
I’m planning on implementing the following:
Replace existing radiator with aluminum radiator (Pantera) with puller fans
Replace all the tubing under the backbone with stainless and/or aluminum,
Safety wire ring and pinion
Modify upper front A-arms for ball joint grease fitting
Modify rear suspension trailing links for left hand thread Heim joint
Change brake lines to stainless
Change flexible brake lines to braided stainless
Larger (stronger) mounting tabs for transmission mounting beam
Any and all suggestions would be greatly appreciated.
Dick Chandler
