Looks like they must not be for use on the stock shocks or it is some very odd Hall mod. I don’t think I’d drive it that way because like you say the locks could fall out. But for that to happen, the suspension would need to extend fully, not sure that could happen on the street. You might find a way to tie the spring assembly up to the upper shock end using wire ties to keep the locks from falling out.
If you just take the spacers out of your stock shocks and use stock springs you’ll have a euro ride height that is pretty nice.
I installed the Pantera East Koni bolt in setup and found that lowering the car 1” more in the front and ¾” in the back from euro was about as far as you would want to be and still feel safe running on the street. I only have 3 5/8” clearance at the lowest point.
http://www.panteraplace.com/page212.htm Note how the wire ties were used on my coil over to keep the spring in position. But the upper mount is held in with a clip so it can not come out.
Can’t tell for sure in your picture, but your arm bushings might be ready for replacement and that is lots of fun.
Mike
