Just fried my voltage regulator and some wires this weekend.Know warning,just smoke and smell of burning plastic when riding around Sunday morning.Lucky I was close to home.Has anyone else had this problem before.When I stoped I sprayed the regulator down with water and unhooked battery cable.Let it cool down and rehooked battery cabe then it restarted with no trouble except negitive charging on amp meter.Could my alternator also be damaged?
You can get a lot out of the pedal generators DU. We had 600volt units in Vietnam. Curious how a suspect will admit to anything with that much voltage running through them.
The voltage regulators on the Pantera are the same as on the 72 Mustang. They seem to die from age no matter how much or little they are used. Don't take it personally.
