I just installed a voltmeter from Hall to replace my ammeter per the instructions on an older forum post (piggybacking from the pink wire on the oil pressure gauge)... but when I hooked it all up, it didn't do anything. Then I remembered that the ammeter stopped working after I hooked up my one-wire alternator (which I was fine with because I never looked at it anyway).
I'm an electrical dummy (clearly!)... so any help to get the voltmeter to work with my upgraded alternator would be greatly appreciated. Thanks.
Can you draw a sketch of how you wired the voltmeter up? The alternator would have no bearing on the voltmeter. A voltmeter is simply measuring voltage to ground. The pink wire you connected to for +12 volts should have power when the ignition switch is in the run position. Have you verified that?
The meter has a ground connection in addition to the case being grounded for the light. One post to +12v and the other post to ground.
Unlike the OEM Veglia gauges, the case of the Hall voltmeter isn't grounded, you need to attach a ground to the post marked negative and switched power to the positive post.
If you use the bulb that comes with it, you need to connect a ground to one of the bulb wires and use the stock amp meter's bulb positive on the other side so it will dim with the other gauges.
I ran a "fresh" switched 12V wire from my fuse panel so I can't answer where the best place to get switched 12v back there is.
