looking for a 72 or newer rear trunk or tub. I live in Missouri, closer the better. Let me know what you got. Text or email
816-507-3003
larrysears06@yahoo.com
816-507-3003
Number wrong
816-506-3003 Thanks
Looking for set of 8” and 11” polished comps style wheels and tires or what have you got ?
816-506-3003
Are you still looking for a tub?
I am curious - how do the tubs change over the model years?
My '71 has snaps and a vinyl cover.
My '71 used bolts to hold it in place instead of the later Dzus fittings. It also is in 2 pieces. It has a fiberglass cover over the AC condenser which is screwed onto the tub. It also has a seprate piece which goes around the deck latch.
My 73 is a single piece insert. When the insert in removed you can see 6 holes with plastic caps inside like the one in the attachment. I don't see how a dzus fastener would attach to it. The previous owner had new felt install in the insert and covered any holes in the body of the insert. When I got the car the insert would just set in the rear and you closed the lid. Anyone have a picture of how it should work.
Allan, this is a classified ad, not the correct place to discuss technical details. So I've split-off your post into a new topic.
I have one if you didn’t buy one. Dan 937 605 1505
danmershon posted:I have one if you didn’t buy one. Dan 937 605 1505
Do you still have the trunk tub available? I’m looking for one to fit my ‘72. Thanks.
Thanks but I found one !! 👍
I am interested in one that is located locally to me. Shipping on those is ridiculous. You can PM me if you have one that you want to sell.
panteradoug posted:I am interested in one that is located locally to me. Shipping on those is ridiculous. You can PM me if you have one that you want to sell.
Doug
I have a tub and am in eastern PA.
PM your email and I can send pictures.
Dominic
dc-dd posted:panteradoug posted:I am interested in one that is located locally to me. Shipping on those is ridiculous. You can PM me if you have one that you want to sell.
Doug
Dominic
Not local enough. Thanks though.
I have shipped a tub and large items via Greyhound terminal to terminal and it works out by far the cheapest method.
I don't want a mint restored tub. A beat up naked one is fine for my purposes. I suspect that there is more then one locally that folks just don't want to get involved in advertising and defending it.
They are back behind the garage collecting leaves or something similar. Maybe even from a car they no longer own? MANY of these tubs that I've seen have damaged bottoms. One of those would be fine.
How mandy different variations of the tub are there?
