What does a stock Pantera weigh? Narrow body in particular, but wide body cars too.
In a magazine like Road and Track and in modern factory specs, is the horsepower listed, taken at the flywheel or at the rear wheels?
I'm trying to get a better idea of how a stock and/or modified Pantera stacks up to modern sports cars.
While we're at it, does anybody know what G's a stock Pantera pulls on a skid pad? I know going to modern wheels and tires and lowering the suspension has improved my grip noticably.
Just stuff I was wondering.
Mooso.
Michael,
unless the magazines pull a motor to test it on an engine dyno, they have only 3 ways to quote bhp figures, (1) on a chassis dyno, (2) to extrapolate the figure using acceleration data or (3) to simply quote the manufacturer's claimed bhp. To my knowledge, they do the latter.
I have access to old magazine reports at home I can post some data later this evening. I believe they do include skid pad results. When comparing skid pad results, you must observe the diameter of the skid pad, if they aren't identicle, then the results aren't comparable.
regarding weight, many magazines simply quoted the manufacturer's claimed weight, Road & Track actually measured it.
Vehicles do 3 things, accelerate, corner & decelerate. Many factors affect the vehicle's ability to perform these tasks, not just bhp & weight. Rather than focus on the power & weight of the vehicle, I would suggest you compare 0 to 60 mph acceleration times, 80 to 0 braking distances and the skid pad results.
Every time you read a 0 to 60 acceleration figure, I would like you to think of a name, Uncle Tom McCahill, the pioneer in automotive journalism who originated the use of this measurement.
your friend on the DTBB
Michael,
the push button that R&T tested in the September 1971 issue had a curb weight of 3155 pounds. They posted a 0 to 60mph time of 6.8 seconds, which was about a second slower than every other publication was publishing.
The "L" that Motor Trend tested in September 1973 had a curb weight of 3580 pounds, 20 pounds heavier than the big block Corvette it was being compared to. This figure seems very high, I think it is bogus.
In August 1984 Car and Driver tested a GT5, riding on Pirelli P7s, at 0.89g on a 282 foot diameter skid pad. In June of that year R&T teste the same car. They published no skid pad data, but the 700 ft slalom was clocked at 62.4 mph. C&D listed the curb weight of that GT5 as 3268 pounds, R&T did not measure the car's weight, only "estimating" the weight at 3250. Car and Driver was able to manage 5.2 seconds from 0 to 60 mph, R&T 5.5 seconds.
Curb weight, by the way, means the car is filled with all fluids, a 1/2 tank of fuel and no driver or passenger.
Thanks, George! It looks like the GT5 is an impressive performer. Even by today's standards, those are good numbers. Just tires and tweaks away from excellent.
So, I understand that if a magazine wants their own HP numbers, they're going to get rear wheel HP from a Dyno run. But when a manufacturer quotes HP, are there any standards? I recall that many years ago they were required by SAE (I think) to hook up "normal" items like air cleaners, alternators and AC pumps when doing dyno pulls, but I assumed those were still flywheel numbers...not rear wheel numbers from a complete car.
I was just wondering if new manufacturers HP quotes are still "engine stand" pulls or are they rear wheel pulls from a complete production model car?
Lots of high end cars hover around 500HP these days. A Cleveland has that potential and more. I just wanted to know where the factory numbers came from and how to compare them to some of the Cleveland dyno charts I've seen.
Thanks for the info!
Mooso.
Michael,
the manufacturers publish engine dyno numbers (flywheel horsepower), not rear wheel numbers. In the US, the SAE specifies "Net BHP", which as you wrote, means the normal accessories are installed and operating. The Euro manufacturers conmply to a DIN specification, which runs about 10% higher than SAE numbers. The Italians generally just pad their numbers 10% higher than their competitors.
Your friend on the DTBB
Thanks for the info guys. I was suspicious that the manufacturers' HP numbers were flywheel numbers, but wanted to get an expert to confirm it. Who better than the "director" his-self!
Sneaky Euros. Cheating on the numbers?! Who would have believed it.
Now when I see a massaged Cleveland pulling 500HP at the flywheel...and the latest BMW multi-valve, overhead cam, sequential turbo, variable timing, direct injected, computer managed marvel pulling 486HP...I'll know which one to be impressed with.
Ughh...Pushrods...Good!!
Mooso.
