Hey Hall misplaced my upper ball joint nuts. I really don't want to wait a week for new ones. Does anyone know what size nuts the rear upper ball joints use, or which car they are interchangeable with?
As it turns out, the OEM nut IS metric but is also virtually identical to a 7/16-20 SAE castellated nut, available at your hardware store for pennies. This is one of only two sizes the SAE/metric trick will work on- must be your lucky day!
quote:Originally posted by jack deryke: As it turns out, the OEM nut IS metric but is also virtually identical to a 7/16-20 SAE castellated nut, available at your hardware store for pennies. This is one of only two sizes the SAE/metric trick will work on- must be your lucky day!
