Kev, welcome aboard.
What you read was correct, the gearbox lubricant does indeed need to satisfy the requirements of a limited slip differential ... plus the spiral/bevel ring and pinion gears, bearings of all types, transmission gears and the synchronizer rings. The lubricant must also be non-corrosive to steel, aluminum, and "yellow' metals (i.e. copper, brass or bronze).
ZF's recommended viscosity was SAE 80 or SAE 80W90. The synchronizers, brass/bronze parts and limited slip differential within the gearbox has traditionally meant lubricants rated API GL-4 are the best lubricants for the ZF. GL-4 lubricants are medium load lubricants in which the additive package has been specifically formulated to meet the requirements of limited slip differentials and synchronizer rings, while being non-corrosive to aluminum and yellow metals. API GL-4 lubricants are common lubricants for transmissions and transaxles. The Castrol 80W90 Hypoy Gear Oil (GL-4) was among the lubricants ZF originally recommended to Ford.
GL-5 lubricants have a higher load rating than GL-4 lubricants, but the GL-5 additive package is usually not compatible with limited slip differentials or synchronizer rings; the GL-5 additive package is usually corrosive to yellow metals too. However, some API GL-5 lubricants contain friction modifying additives specifically added for limited slip differential usage (the label should specify it has a modified API rating such as GL-5+ or GL-5-LS). API GL-5 lubricants are common lubricants for axles that are independent from the transmission. Even when modified for limited slip differentials GL-5 lubricants are not usually considered suitable for the synchronizer rings & yellow metals in a transmission or transaxle. However in the case of Castrol's current 80W90 Hypoy Gear Oil (which is rated API GL-5) Lloyd's recommendation indicates to me it must be OK for the ZF. Smiler
At least now you understand the issues.
Why not run Brad Penn GL-4? It works very well in a ZF and is what was specified from the manufacturer. If you want a synthetic, then Pennzoil makes a great GL-4 specific one, but you will need to buy a case and it is expensive. I switched to the Pennzoil synthetic because I live in a cold climate and it did improved the shifting when cold, but did not improve the shifting when hot over the Brad Penn gear oil.
Summit racing sells the Brad Penn GL-4 oil and can have to your door in a few days.
Roy Butfoy, the master rebuilt my ZF 20 years ago. As I was leaving Lance's shop, he looks at me and says "change it once a year, and use Castrol 80W90 Hypoy C." Use nothing different, and never do not change it once a year."
I never forgot what Roy told me and I have faithfully done that. Roy didn't say GL-5. He just showed me the bottle and said buy this.
I live in SoCal, and my ZF shifts like butter, does not leak and is perfect.
So that is what I choose to use.
Lee
