The factory published specs in 1980 for the then-new GT5, which run the same size tires as your car:
-1/8 frt camber
3/64-5/64" frt toe IN
5/64 to 5/32 rear camber
5/16 to 11/16" rear toe IN.
No mention made of front caster. I recommend as much as possible, which will be about minus 2-1/4 degrees, will not be enough, and will vary a little from side to side.
what wheels are you running?
Originally posted by paul ritzen:
My 1973 pantera needs a wheel alignment.
Perhaps you could help me with the correct
technical data.
Tire size front, 285/40 15
rear, 345/35 15
Thank you very much for your help.
Greetings Paul Ritzen.
Weert, Netherlands.
My wheels are from hall pantera
as far as i can see , it's a mark 8 type
wheel with knock off-wings.
fits for front tyre 285/40 zr 15
and for rear tyre 345/35 zr 15
I don't know if its possible to get a picture of my car on the net, so you can see
how it looks
Greetings, paul ritzen.
