I took the lugs off of the left rear - the car is on jack stands - and tried to pull off the wheel, I hit the inside of the tire and wheel with a rubber mallet but still no movement - it is like the weel is bonded to the hub, what gives? I took out the jack stands and dropped the car to the ground with the jack a few times hoping the weight of the car would cause the wheel to separate from the hub, to no avail.
