n trying to legalize my recently acquired US Pantera, I have to have white parking lights and yellow blinkers. Has anybody a good solution to getting this done on the early cars like mine where it's placed in the bumper?
Get a pair of clear/white turn signal lenses. Tell the officials those are the running lights, and the side markers are the blinkers.
Or for a more involved solution...
Cut the clear lenses in half and do the same to your yellow lenses and glue/epoxy them together to make two toned lenses. You will then need to modify the bulb housing by moving the existing bulb socket, adding a bulb socket, and putting a wall plate between the two halves.
Here's a picture of a friends Pantera with the white turn signal lenses. I've emailed him to find out where he bought them and will let you know.
