205/60-15 tires will fit stock front Campy's just fine. They will only rub if you it a driveway/bump at speed while turning the wheel - then you run the risk of having your tires grab the inner fender lip and pulling it down/out. But then again, that risk is present with any of the common tire sizes.
Here are some pics of my car when it wore 205/60-15's on the front:
http://www.banzairunnerpantera.com/gallery_4033.htm
