Dennis,
My Wilwood hats are installed the same as the oem rotors, as Mark described above. They don't just slip off the wheel studs, they're mounted behind the axle flange sandwiched between the rear of the flange and the stud bolt heads.
If yours are mounted the same, then removal of the disk requires disassembling the stub axle from the carrier/bearing. Then you can unbolt the disk from the hat. You wouldn't have to press out the wheel studs, just leave the hat in place.
your friend on the DTBB
OK, taking a closer look, I can see the wheel studs going into the axle flanges behind the rotor. Doesn't this mean that the rotor slips onto the studs/hub and I should be able to just pull it out without disassembling the axles? It's still stuck. While there is quite a bit of corrosion on the outer axle, I would think that it should come off easier. Any ideas? Thanks in advance.
Originally posted by DeTom:
I recently came into a complete set of Wilwood Superlight brakes.
That's a common problem Dennis. Don't worry too much about it, and next time try thinking about baseball for awhile first. It helps. Wink
..................................................Thats funny Dethom!
How does the parking brake work on these?
I don't have a parking brake yet on this car but my last car used a micro lock for the parking brake. just flip the valve and push on the brake to set probably not dot approved but it worked.
I'm looking in to a second small caliper for a parking brake on this car.
Wilwood is saying that their stock Pantera kit will only fit with 17" or larger wheels.
They will custom make a set for smaller wheels.
Is it worth the effort? They just quoted me $1650 for the fronts and $1875 for the rear for the stock set.
The rear uses a seperate caliper for the parking brake.
I might have misread the Pantera East price list but the kit they sell is $1850 with wilwood lettering and $2150 for Pantera lettering.
That's a big difference from what I just got quoted.
Dennis,
I have an older Wilwood kit, with 12.75" diameter rotors. I took a tape measure out to my car, I have the front wheels off at the moment, and I eye balled my brakes for you. It looks like from center of spindle to the outer edge of the caliper is about 7.5". If this is so, then a 16" wheel "should" fit, although clearance with the caliper may be tight. What happens when the clearance gets too tight, the glue on balancing weights get scraped off the inside of the wheel. I've seen this happen.
Can't you take a wheel off your car & install it on the donor car, or on the donor spindle, & determine if its going to work?
I just measured my rotor . . . 12" from edge to edge, 6" from spindle center to the edge of the rotor. Could I have lucked out and have one that would fit a 16"? (pardon my terminology, I suck at math and measurement!) I'm preparing to leave on emergency family business in Korea in the morning and will have to wait to try the wheel. Keep your fingers crossed! Thanks again guys!
Curiosity got the best of me, took the rear wheel off the wreck (The front of the wreck is dismantled)and threw on my 16' x 8" front wheel off of my car and it fit! The rotors and calipers are the same size, unless the fronts are mounted somehow different than the back they should work. Thanks again for the help and suggestions. Sometimes the obvious passes me by!
