Well I guess it was only a matter of time but my drivers side window has stopped working. It had the brass gear mod done by the previous owner. Leading up to the failure it would intermittantly not work but seams to work if I fiddled the switch. Now all I get is a high ammeter reading. Is there any chance this is a switch problem? Just jammed?
If it is the motor:
Can I change it out for the one in the passenger door (no left right issues)
Can I have this one repaired?
Odds of finding a good used one
Am I stuck doing one of these conversions I read about on this forum to a newer motor
Is there a manual alternative (crank handle)
Gavin
Gavin, it could be the window is stuck in the guide as I found out when my windows started to get very slow. You could hear the elect motors working hard and straining. I removed the door panels and soaked all the guides and linkage with lithium grease which improved window speed and smoother operation. Try pulling on the glass and activating the switch, but do not hold the switch for a long period of time as this could damage the motor. There is also the manual control that you can roll the window with the correct tool. I can't remember what it is, socket , allen wrench.
Otherwise Will can narrow the problem for ya.
