For your information.
Heard from local Pantera fellow that he found decently priced windshield from a small glass maker in Finland (<300euros).
I think they are able to make molds if one has a model. We will check if they are willing to make others like side windows as well as Jocke would need those. Haven't talked to them directly yet and not sure about their language skills, but will be happy to help anyone interested. Could be an opportunity for Goose owners, if someone is willing to go to an extent to get model glass here.
Called them. They have Pantera windshield in stock. The ones in stock are slightly greenish glass with dark blue shading in the upper portion of the glass. They can be had without that tint as well. The price is 260e + wooden shipment crate 80e. Shipment would then come on top of that.
These fellas do not speak English, so I'd need to help with communication etc.
They will also custom make glasses that can be Laminated, if customer provides model glasses for pattern making. This means they only make glasses that are solidly supported all around, like windshield and rear glass.
Door glasses need to be hardened to last, and they can't make them unless what you need is straight glass like in many fifties-early sixties cars. Laminated curved glass in doors would break in use almost immediately if you close the door with window halfway down.
EDIT: Maybe you can PM your address, so I can check shipping with them. The crate will make it possible.
I called them. They also do have english information on their webpages, but it does not really answer into any of our questions http://www.jaakko-tuote.fi/
That side window is propably more than ten years old, done during the earlier worker. But because they have made it once, they will propably be able to make it again. Rough estimation for the price per side window was 150 euros. That is just the estimation. They will need examples (or exact measurements) to start with. I don´t have my side windows here right now, but I think, they are curved only to one direction? Because that´s what they can make, not the versions, which are curved to two directions.
He was not able to answer the shipment questions immediately. That can always be arranged, of course. And my side windows are already out of the doors, if needed for models.
An update:
The price for regular glass is 260e + wooden shipment crate 80e. Shipment would then come on top of that.
Available greenish (typical Pantera), clear (have heard some early cars would have), also available with green or blue darkening at the top of the glass (no price incremental).
They have a heated glass with visible resistor wire at 400e. Typically used in race cars.
They can also offer heated glass with "invisible wire", but that requires ordering 4 similar windshields at the same time. The price would be 500-530e each, and needs to be verified at order time, as they outsource part of this.
