The drive gear on the front of the cams are different in OD and skew angle. I think the distributor bore in the blocks are at different angles. Trying a Windsor dizzy gear on a Cleveland cam will work for about 5 minutes. Then since the drive is on the extreme tips of the cam gear teeth, it wrecks both the cam and dizzy-gear.
