Installed.
Other Side.
Slave cleaned up and installed. (I'll ge tto the nasty looking bolt today)
Water bottles installed.
Almost done!
Almost done!
When it's time to test your cooling system, I would revisit the positioning of your Meriah Fans. Check the flow through the radiator (with smoke or string) with the fans blades in your current position then with the blades an inch back. You will find, as I did, that you have a lot more air flow thru the radiator wth blades pulled back an inch. When the blades are too close, a lot of the air bounces back off the face of the radiator core that you really need flowing when cruising in town.
I appreciate the input. I moved them as far back as I could. Maybe a 1/2 an inch. wait and see how it works.
Brake and clutch fluid refreshed and tires back on.
.Spreader bar installed.
Finished painting the heads,
New wires and looms ready to go on.
Almost Done!
Good thing we have rain forcasted until the weekend.
Water tanks and hoses installed and Larry cut the main tube from the block to make it level with the swirls tank. We suspect it caused and air pocket previous because it was going "up hill"
Installed the painted carb.
Did I mention I love my wife for hand painting the carb and valve covers!
Air cleaner installed.
New filter.
Larry and I decided to re-do the fuel line.
Reversed the fuel rail,
Mounted the filter on the back of the intake with a braket from one of his motorcycles.
(That's an allen wrench sticking up)
The future fuel line routing.
(Cut in the filter with new lines.)
DONE!!!!!!
Motor's all done and new line ran. Water bottles look great and she's never run better since I've had the pleasure of ownership. Temp stays cool, no leaks, easier starts, and she looks pretty to. (My lovely wife gets credit for the carb and valve covers!)
At home in the driveway after getting inspected. (Love the new look from the rear!)
