My wipers stopped working and the switch felt loose. It fell apart and looks like it was epoxied before....does anyone have one for a reasonable cost, or so I have to refix the one I have? I do not care if it has a chrome or black bezel, just that it is the correct size rocker switch for my 1973 European Pantera that is so good to me. Is a new and improved switch available? Thanks for any ideas or replies.
I understand the same switch is used in Jaguars and other English make cars. Maybe find a salvage yard that has English cars or stop by a Auto-Electric Repair shop and show the switch and ask the guy.
Please let us know what you find out.
Got caught in the rain, did ya? Can be a BAD Experience Panterrible! Even after you get home safely, spending hours on the side of the road, waiting for it to stop raining w/o wipers. Been there, done that.
Check for mud behind the splash shields, this holds moisture for days and thus accelerates rust 300-400% in those areas. I hosed mine out with an air gun, dusty project....
Let us know about the switch solution.
Ron
Originally posted by Panterrible:
Any other ideas or parts? Anyone?
Panterrible, check www.ebay.com because once in a while guys are selling stuff like that. You know, the guys who want a new switch because the chrome is not perfect on their old switch. Sometimes you can get a deal. I paid $20+S&H for a headlight switch.
But to get the real fix, you're gonna have to do the Lucas electrics modification to off load power to your switches. See www.panteraplace.com search technical site, look under electrical systems, Relay Modification. That's the reason your switch was epoxied back together to begin with. Too much current going thru the switch. ALL the switches.
If you don't do the relay modification, you'll sacrifice reliability and have to keep changing one switch after another, and they're expensive.
My wiper switch fell apart too. It is easily refurbed and reassembled if you have all the parts. Inside there is only a small plastic block with a c-shaped brass piece that goes around the plastic part. The two switch halves then snap together or could be glued.
Just my experience
