On the right side of the car below the dash and next to the fuse block is a pair of white wires moulded together like radio speaker wires that go into the wiring harness. These wires in my car were cut off and just hanging. See picture below. I thought that they were speaker wires however one of the wires has 12 volts power to it when the key is on. Any idea what these wires may be for??
Maybe for the aircon switch ?
That zip cord speaker wire looks suspiciously the same as the wire used in 2511 to supply the dome light.
I have taken my wiring harness completely apart recently, and I did not have those wires. Must have been an add from a previous owner. Definitely NOT Factory. I guess you need to un tape some of the harness to see what it is wired too.
Indeed they are power wires to the courtesy light!! Who would have guessed with such small diameter wires!! It took a while to figure out because of the courtesy light switch and the door closer switches.... Oh well..... On to the next issue!! Thanks to all for help!!
We all know the words “not factory” when applied to our cars is often a gray, not definite black and white, situation.
Until I saw Greg’s photo of his zip cord wires I, like Lardog, also thought the same wires in 2511 had been added during a previous restoration in the 1990’s.
during the reassembly of 2511, I was in intimate contact with all of the wiring harness, and there is nothing else like that zip cord anywhere else in the harness.
perhaps it was something that changed later in the production process?
Curious what Greg’s VIN is and also the VIN of Lardog’s car.
The power to the courtesy light should be hot all the time, not just when ignition on.
@If-tp2511 - My VIN is #3648. Larry
For prosperity sake, I have the same wires (2/72) marked Radio. If 12v Key on engine off power would make sense.
