See how long your ZF lasts behind one of these
quote:Originally posted by PanteraDoug:
It isn't so much the HP but the torque that will do in the ZF.
As per a previous discussion, Butfoy only guarantys his ZF's for a maximum of 550 ft-lbs.
That pretty much eliminates strokers as I understand it?
quote:Originally posted by Hustler:
HP after all is just a derivative of torque. Hence why most transmissions are rated with torque values.
That is what the equation says but if you will notice there are quite a few 357's running with 650 to 750 hp and just about 500 ft-lbs.
Butfoy rates in torque.
If I understand the equation correctly, and that depends on how much Bud Light I have consumed, if the hp is up but the torque is remaining constant then it must be the T, or the time in which the torque is being delivered is shorter?
Still that puts the ZF in a safer mode.
If someone insists on running the equivalent of a 427 with 500 ft pound right off of idel and topping out in the 650 to 700 range I would bet you a nickel that the ZF doesn't have an icebergs chance in Hell?
