Am trying to pull ZF off motor today and have run into a very stuborn engine side jam nut at the linkage adjustment point. Clearly this linkage has not been apart in years. With a little umpf and Kano Kroil spray, the jam nut closetest to the zf shifter box jam loose. The other one is a killer. No go with umpf, Kroil spray, and/or heat. I am making the assumption the thread on that end of the adjustment point is normal counterclockwise rotation of the nut to get it off, right? It's not some odd ball reverse threading is it?
Appears to me that pulling the ZF and ultimately the motor is at a stand still until I get that jam nut loose and can disconect the ZF.
Any ideas?
Thanx
Mark
