What are the losses through a Zf? I've heard everything from 15-25% Does anyone have dyno proof?
Will
quote:Originally posted by Charlie McCall:
This has been kicked around before, but shouldn't the loss be an absolute number and not a relative number? Ie, 75 hp is absorbed through the ZF. If it were a percentage, then a high HP engine would lose more power through the same ZF than a stock engine. The ZF doesn't change, so the loss should remain constant.
RIght?
quote:Originally posted by Perry H:quote:Originally posted by Charlie McCall:
RIght?
While I can't cite any engineering sources, logically the loss has to be a function of the input (and that is always the way that I've seen flywheel HP calculated from rear wheel horsepower).
Think about it like this... using your hypothetical 75 HP constant loss, if someone put a 50 HP engine in their Pantera and put it on a rear wheel dyno, could the 50 HP engine turn the rear wheels through the ZF? If so, (and I think it would) then the loss couldn't possibly be a constant 75 HP.
The actual function almost certainly isn't a straight percentage either. It's just close to linear in the normal power range of most passenger car engines - so losses are estimated using a percentage. More than likely, the percentage loss increases at the power increases. (this might be a poor analogy, but sort of like wind drag, where the drag force increases as a function of the square of the velocity)
quote:OK, the same question phrased differently. How does the ZF know if it is connected to a 75hp engine or a 750hp engine? Shouldn't the internal resistance be the same? A higher powered motor will be able to overcome that resistance more easily, but the resistance will be the same, right?
(btw - general consensus seems to be that it is a percentage.. just trying to understand the logic behind that)
