Does anyone have first hand experience with confirmed ZF losses? I've read that they are in the 20% range.
Has anyone dyno'd their engine, then had the car chassis dyno'd to compare?
Will
Will
Yes, Ive read 22-25% many times. Never actually heard of it verified, though.
When do you plan on going to the chassis dyno?
What were your engine dyno numbers?
Will
quote:Originally posted by Belgiumbarry:
sorry, but what do you guys mean with power loss trough the ZF ? if i'm right , power can't go away ... so just be converted to heat due friction i suppose ?....now i don't think a small box like the ZF can dissipate that amount of heat equivalent to 80 HP ... sure not without a massive oil cooler ???
i estimate : ZF box max 2 m2 x (120°C oil temp - 20° ambient temp ) x 50 Kcal/h ( high wind speed ) = 10.000 Kcal/h... that ZF box would act as a 12 KW stove... ! and this is what ??? 15 HP??? or i'm i wrong ????
quote:you filled it up with diesel by mistake
quote:Originally posted by JTpantera:
It does seem that 75 to 80 hp is a high number. Perhaps it also accounts for the air filter, higher engine bay temp and full muffler system often not included on a bench dyno.
I can turn my ZF by hand; heck, out of the car, my drill would turn it. I certainly think my 5 hp lawn mower could spool it up pretty nicely, although I admit I've never tried. :^)
I recognize that at higher RPM, it would experience higher frictional losses. It just seems that the figure is overstated. I owned two opels that had 100 hp engines. I don't think 3/4 of their power would have been lost to the ZF. Just doesn't pass the sniff test.
JT
